gilford
I've had my 42" Panasonic PF20 mounted in my lounge via a bracket supplied by an AV fitting company who have now gone bust
Over the weekend I have bought a Samsung 46" ES8000 and have fitted it using the same bracket.
All is ok but it does look a tad low compared to how my PF20 looked, which was dead centre to my surround speakers - see here for pic
http://www.avforums.com/forums/13663670-post284.html
Now, I'm useless with DIY, hence me paying someone to fit it, but is it sitting low because the mount I have is for up to 42"? I have got it mounted in the top hole so it is as high as this mount is going to get.
Is it just a simple case of getting a new mount for a larger TV and using the display bit (saves me doing the wall plate again)? Will there be more adjustment?
Cheers, and I hope the above makes sense!
