TV bracket on plyboard?
deb63
Someone told me that prefab house has plyboard walls, and I was wondering weather a tv bracket with a 32inch tv attached to it on the plyboard will hold the tv they said that the the wall will come down with the tv is this true? i dont want to risk it without second advice so please help me out :)
Mafo
:thumbsup:
I agree.
If its plywood then there will undoubtedly be timber stud work behind. See if you can find a vertical / horizontal stud behind the ply and then you can just screw directly into that with some good quality long(ish) wood screws.
Safe as houses ;)
