RickyLee53
Established Member
Hello,
I'm looking for advice for a Vesa 400 x 400 TV bracket for my Sony 85" TV.
Its 44kg, so not too heavy. I have built an Alcove for it to sit in, so ideally want a bracket 40-50mm max, which will make the TV flush. Its a solid wall behind it so no issues there.
The only issue is, I want to be able to move the TV out to make access for cables easier. The recess is tight, 10mm either side and above. 100mm below, Which will allow my sound bar. To sit under it.
So to round up;
100mm forward and back movement.
44kg capable
Vesa 400
Slim, 40mm approx profile.
Any help?
I'm struggling.
So to round up;
44kg capable
Vesa 400
Any help?
I'm struggling.
