phillyd1981
I've got a Philips 50put6400/12 TV with a black screen and I think the issue is with the backlight.
If I turn the TV on after leaving it plugged in for 5 mins I get the logo display for 2 seconds then the back light goes out.
If I plug the TV straight in then power on I get just a black screen with the backlight not coming on at all.
If I shine a torch on the screen I can just about see a image and use the menus.
Looking at the power board that the led panel cables plug into I can not see any blown capicators or any visible damage.
Does anyone have any advice on anything I could check or test.
Thanks.
Thanks.
