mgfredy
Established Member
Good morning
I have looked this question up in here and the general concensus is yes you can.
I am looking to install a 6k wood burner which will be inserted flush into our chimney breast. we are looking to get something like the westfire unique 32 picture I have attached of what this looks like. The issue is I have a 42 plasma above it with a my b and w fpm 1 centre speaker slighly below.
The chap in the fireplace showroom said to move tv and speaker as the stove will give off to much heat. The problem is there is no where else to put the tv.
I have attached a photograph of what it looks like know.
Any ideas of how to reduce heat I thought of putting in place a stone shelf but that would need pillars as supports and I am trying to keep the fire looking minimalistic if that makes sense.
Has anyone done this if so has the tv been affected and or what other ways are there to reduce the risk of heat damage to the tv and speaker.
I am looking to put all the av equipment in a cabinet to the left whats the best way to run the cables as the chimney breast will get incredibly hot channellig the wiring into the plaster is risky as the heat will be so strong.
On the off chance has anyone any experience of this type of fire/ recommend any other thoughts and finally any installers in the east midlands
Thanks in advance for your help.
James
James
