TV Aerial Spur
Discussion in 'Cables & Switches' started by Nelviticus, May 26, 2005.
  1. Nelviticus
    Nelviticus
    Jun 21, 2003
    473
    Hitchin
    +69
    Hello there I have a rooftop TV aerial with a cable running down the side of my 2-storey house and in through the wall on the ground floor. I'd like to run an extra stretch of cable around the side of the house to a room on the 2nd floor. What do I need to buy/do?
    The chap who installed the aerial said that the signal was very strong and if I wanted another spur I wouldn't need any kind of booster. However I'm not the world's greatest electrician and when I tried to do a similar thing at another house a few years ago it was a disaster, I went from one cable with a good signal to two cables with bad signals.
    Is it reasonably easy for an idiot to do or should I put my hand in my pocket and pay an installer?
    Regards
  2. hpoom
    hpoom
    Jun 24, 2005
    1,031
    41
    +22
    I don't know what you should do. But I have the exact same issue myself.
    I moved into my current house a few months ago, I have a 30+ year old aerial on the roof with cable running down the outside of the house to the lounge. I have a freeview box and get good reception ( except I don't get BBC1, BBC2, and BBC news 24 but I didn't get them in my old house 3 miles away ).
    I want to get a new TV with built in freeview and was going to move the old freeview box to the second bedroom. The room currently uses a portable aerial and gets a snow picture on all channels.
    Should I
    A. Split my current lead from the aerial
    B. Split and boost my current lead, using an UHF amplifier splitter box
    C. Put a second aerial on my current pole and feed that to the bedroom ( saves screwing up my current signal to the lounge )
    D. Do either A or B, but also get a new aerial ( as current one is old )
    Thanks for any replys in advance, I have browser the forums but found very little help regarding the pros and cons of splitting an aerial.
    Sorry I haven't helped Nelviticus, maybe we will both get a reply now ?
