TV, Aerial & PC tuner card troubles
Discussion in 'Televisions' started by JimB, Jan 20, 2004.
  1. JimB
    JimB
    Aug 26, 2002
    65
    Devon
    Hope this is the right section to ask this as my query is TV/aerial related.
    My main aerial feed has a Y-splitter on the end. This is connected to my main TV & video, and my PCTV tuner card.
    Problem is, when I touch the coax plug from the tuner card & the coax plug from the tv (at the Y-splitter), I get a mild electric shock. This is a continous current.
    I have tried the TV and video separately and problem occurs with both.
    If I try a different TV, no electric shock.
    So, are my main TV & video at fault? Or is it the tuner card?
    The tuner card is new and I didn't have any problems previously with 2 tv's attached to the splitter.
    I've rewired & checked all leads and tried different splitters and leads.
    No problems with TV or tuner card when I plug them in independently of each other.
    Anyone have any ideas?
