Hi all
I had a free view aerial installed. We have a loft bedroom and no proper loft/roof access so engineer said he couldn’t fit a large aerial mounted on the roof as there is only a very small hatch. Hatch is large enough to reach into but not large enough to get inside the roof cavity. For this reason, he instead used a tiny aerial and basically rested it in the hatch with no fixing so it’s floating on the insulation.
Is this acceptable for an installation? See attached pic.
It does work and does the job but it’s not exactly a nicely secured outside tv aerial like I see on almost every other house in our street.
Would appreciate your thoughts. Thinking of getting another company to come out for an assessment / second opinion.
Alykat
Alykat
