Due to my current situation it is impossible to fit a standard outdoor high gain Aerial. However, I would really quite like digital but with a standard indoor aerial this is impossible . I recently came across this Aerial however
http://www.turbosat.com/acatalog/TV_Aerials.html
It seems perfect for what I need because i can just "no more nails" the bugger to the wall, however, I dont know it if will provide a suitably good signal. Also I am reluctant to spend 60 quid unless i know it will be good.
I recently spoke to an Aerial fitter and he said it is possible to get reception good enough for digital where I am, so it is just a matter of getting the right Aerial.
Can anyone offer any opinions on this? If so could anyone suggest any alternatives, preferably abit cheaper but a similar type of thing.
I have spent hours looking for around the net at this stuff to abseloutly no avail, and I would be extremly gratful if anyone could offer any sort of advice.
