TV Aerial - confused
TheBlueRaja
Hi all,
I have an aerial in my loft which connects to a powered distribution box, all the Ariel cables to the TV's in the house hang off this. Pretty standard setup as far as I know.
We started to get picture break up however out of the blue so I went up the loft and redid the coax connector from the arial as it seemed a bit poorly done in the first place.
This didn't really help though, it stayed pretty much the same as before, so I thought I'd get one of those male/female connectors to bypass the box (to check if the box was on the way out) and connect the aerial directly to a single TV, but when I do this I get no signal on the TV.
Is there a reason an aerial connected directly wouldn't work?
edders5
Just spotted this so you may have already resolved it, but I suspect that your distribution box also amplifies the incoming signal.
By bypassing it, the signal is too weak for the TV to use. So your distribution/booster box may need replacing if all the connections on all of the cables are OK.
Podcast: Best Home Cinema Sources and B&W 805 D4 Speaker Review and more...
