Tutorial: Increase MCE Buffer to help Media Playback on the 360
Discussion in 'Xbox Forums' started by Chrisoldinho, Feb 9, 2009.
  1. Chrisoldinho
    Chrisoldinho
    Feb 7, 2006
    3,445
    Leeds
    +267
    If like me you occassionally suffer from a pause whilst using the Xbox 360 Windows Media Extender whilst your PC buffers the next bit of audio/video every so often (so annoying) here is a simple solution.
    Download the following application:
    http://www.coombsfamily.com/download...derUISetup.zip
    Unzip it, run it and choose your preferred buffer size from the drop-down list. Easy as!
    What it does in a nutshell is increase the buffer size from 30 mins to 2 hours which should be plenty for those of you streaming a movie or an album to listen to it uninterupted.
    Chris.
  2. Chrisoldinho
    Chrisoldinho
    Feb 7, 2006
    3,445
    Leeds
    +267
    Mods can you change the title to:
  3. smallclanger
    smallclanger
    May 9, 2007
    2,246
    Southampton
    +463
  4. blynch6038
    blynch6038
    Oct 25, 2009
    Can someone please post a link to the file? I tried to use the one in the post but the file is no longer there.
