Turtle Beach X3 Headphone setup Question?
Discussion in 'Xbox Forums' started by eddywatson, Feb 9, 2009.
  1. eddywatson
    eddywatson
    Feb 9, 2009
    84
    Hey guys Ive just bought some Turtle beach x3's from America. And i have a question....
    Can these ONLY be used with VGA cable? as the red and white cables for output is needed and HDMI does not have them. Or is there another cable that i can use so that i can use these headphones while using HDMI?
    I hope somebody can help, thanks!
    EDIT://
    Or will the official xbox360 HDMI cable work?
    [​IMG]
  2. markwww673
    markwww673
    Oct 31, 2003
    2,978
    103
    Midlands
    +321
    The official HDMI has all the connections the x3's need.
  3. cas398
    cas398
    Nov 25, 2007
    2,530
    Glasgow
    +184
  4. markwww673
    markwww673
    Oct 31, 2003
    2,978
    103
    Midlands
    +321
    X3's don't use optical only the x4's. The x3's use a L/R splitter cable that attaches to the l/r on the hdmi out. The optical out is also on the back of the hdmi so it you get the X4's your sorted. The X3's are a wireless version of the X1's which I am just in the process of selling.
    Mark..
  5. eddywatson
    eddywatson
    Feb 9, 2009
    84
    thanks guys, so for this to work VIA HDMI....
    I will hve a HDMI cable plugged into the back of my 360 AND that gray box that comes with the officla 360 hdmi cable? so the hdmi will do the video and that gray box with do the audio (red and white)
    So in the end BOTH outputs from the 360 will be used(HDMI + Other connection(gray box)?
  6. cas398
    cas398
    Nov 25, 2007
    2,530
    Glasgow
    +184
    :oops: Sorry, I mixed up the models.
  7. markwww673
    markwww673
    Oct 31, 2003
    2,978
    103
    Midlands
    +321
    The x1 or x3 will use the hdmi out box for video and the l/r outputs for the audio.
    Mark..
