Quantcast
turtle beach px5 and blu ray player
pat clancy
Hi chaps I cant seem to get 5.1 from player to headset when watching movies,analog is fine,its connected via optical,any thought appreciated
r.vernon1
Did you resolve this? I had the same problem, I found the optical lead was plugged into the wrong connection on the tb box. There is an input and an output, I had it plugged into the output socket. Doh!
pat clancy
They sound quite good,I,be just done a comparison with private Ryan DVD, front to back effect not bad at all.
What preset do you use?
r.vernon1
I didn't really find it made much difference really. I think the one which which turns up the bass for explosions worked the best for action films. But mostly left it on default.
Glad to know it's not just me that has done this then ;)
Similar threads
