Turntable works fine for 45 rpm lps but slow with 33.5 rpm lps???
Discussion in 'Hi-Fi Stereo Systems & Separates' started by alikhan, Dec 26, 2004.
  1. alikhan
    alikhan
    Hi guys, any one would know why this would happen? Everytime I change the belt to suit the 33 1/2 rpm LPs, it run so slow that the pitch is almost halfway down. Abd in 45rpm its running just fine. Leads me to believe that the motor couldnt be messed up at all.
    Any suggestions?
    Regards...
    Ali
  2. SKA.face
    SKA.face
    Whats the deck?Rega? sounds like the belt is on its way out,on 45s the belt is more stretched so you won't notice it,whereas on 33rpm it will be more slack,hence the slow speed.
    If it's a Rega they go on for yonks.........................................................
  3. alikhan
    alikhan
    yeah it is REGA planar 3.. whats the solution? new belt or some cleaning would do?
  4. SKA.face
    SKA.face
    Planer 3,so fairly old,yes change the belt,about £9.Had the same problem on mine,now have the P25 hmmm..nice.
  5. Londondecca
    Londondecca
    Dec 21, 2003
    2,082
    +97
    Agree, change the belt and make sure everything is nice and clean
  6. alikhan
    alikhan
    thanks guys.. turns out that the pulley is loose from the motor shaft and it not set on it all the way. All I had to do was push it down and viola!!! thank you guys for your time and your advice...
