Turntable with Marantz PM4400
Discussion in 'Hi-Fi Stereo Systems & Separates' started by Amure_87, Sep 23, 2005.
  1. Amure_87
    Amure_87
    Apr 10, 2005
    4
    Hi there. I have a slight problem with my turntable and amplifier. I don't have much experience of using vinyl, so am not sure what I'm doing wrong. I have plugged my turntable into the phono input on my amp, but I'm only getting sound from my speakers at a very quiet volume. Will I need to buy a phono stage? And is it a bad idea to plug the turntable into one of the other inputs? I'd appreciate any help.
    Thanks,
    Daniel.
  2. daveb975
    daveb975
    Oct 25, 2002
    3,951
    103
    London
    +271
    What TT and cartridge are you using?
    The Marantz amp has a MM phono stage, but will not work with MC cartridges.
    If you have an MC cartridge you will either need to buy a phono stage or replace it with an MM cartridge.
    Do not plug the TT into a non-phono input, you will always get a very quiet sound that way.
  3. Amure_87
    Amure_87
    Apr 10, 2005
    4
    The turntable I have is a Pioneer PL-12D (from the seventies). But as for the cartridge, I have no idea. I'll have to investigate that. Thanks for the advice
