Turntable suitable for 78 rpm
Discussion in 'Hi-Fi Stereo Systems & Separates' started by Franco50, Oct 1, 2004.
  1. Franco50
    Franco50
    Sep 21, 2004
    499
    West Lothian
    +37
    I'm looking for advice on buying a turntable with 33/45/78 rpm speeds to allow me to archive some old records to CD. I also understand that some 78 records have a slight speed variation so a deck with a variable control might be advantageous. Also, presumably I need to change cartridges when switching between vinyl and 78s? Cost effective suggestions welcome please.
  2. overkill
    overkill
    Nov 6, 2003
    11,792
    Murkeyside
    +1,201
    Hi, this might be the one:- Dual CS5000 or for a new table' Project
    With the Dual I would check for belt wear, bearing wear etc, before buying if poss.
  3. hornydragon
    hornydragon
    Dec 19, 2001
    28,294
    +1,217
    Project Phono SB with optional Stylus 78 Should cost you £225 and connect direct to CD recorder as in has an internal phonostage.
  4. bobbypunk
    bobbypunk
    Thats a bit pricey i would expect that setup to sell for £210 seeing as the Phonosb project debut is £170 and the stylus78 is £40.
