marc1986
Hi all, first post
I am currently thinking of upgrading my turntable. The TT is a few years old, but looking to upgrade to compliment my new set up, as I have just bought a Sonos amp & Dali Oberon Speakers.
What this new set up has done is made the buzzing very apparent from my new speakers. I used to get that buzz from my previous Edifier bookshelf speakers connected to my pre amp but was minimal. (When connecting my phone to the amp for music there is no issue).
I have tried all the forums and also asked my tech mate to send over thoughts. Due to no easy grounding options on the turntable I have run out of ideas and not savvy enough to really pick apart electronics.
Current set up;
Probably two parts to this post;
1. What turntable would you recommend to compliment the above specs which would also eliminate/none background noise (money £300-£800)
2. Any advice on my set up to get the best out of it
Collected vinyl for 10 years now and just moved from a flat to a house so excited to expand the sound and would need expert advice which I'm lacking in!
Marc
Current set up;
- Rega Planar 1 turntable
- Behringer PP400 Ultra Compact Phono Preamp
- Sonos Amp
- Oberon Dali 1 Speakers
Marc
