Turntable help
Discussion in 'Hi-Fi Stereo Systems & Separates' started by bluewire, Dec 27, 2004.
  1. bluewire
    bluewire
    I have a Denon UD-M5 system & want to attach a turntable to play all ny old vynl, any reccomendations on turntable to attach?, as far as I can see only inputs left are usual aux pair inputs.
  2. SKA.face
    SKA.face
    Well,a Turntable wont work from Aux,it needs a phono line to boost the signal,so your probably best of with a Project turntable that comes with the inbuilt phono stage.
  3. bobbypunk
    bobbypunk
    or any turntable but an external pre amp.
    Project's Debut MKIII or Expression are good considerations with a Nad PP2 or project's own pre amp!
