Turntable Advice Please!
Discussion in 'Hi-Fi Stereo Systems & Separates' started by digitaldave, May 16, 2005.
  1. digitaldave
    digitaldave
    Jan 7, 2003
    261
    St Evenage
    +12
    I'm thinking about getting a turntable to add to my sound system, and was originally looking at the Pro-Ject Debut III and possibly the Goldring GR1.2. However, it seems I might have more money available (up to about £200 I think), so that opens up more options, such as the Pro-Ject 1 and 1.2 Expression. So, what are the differences between the Pro-Ject models? Do they all have captive phono cables? Is the carbon arm of the 1.2 Expression worth the extra?
    So should I just go with the entry level Pro-Ject or Goldring, or would it be worth spending the extra for the higher model?
  2. SKA.face
    SKA.face
    Personally I would go for the Rega P2.Enjoy it as it is,then later add things to it to make it better.It's a simple fit and forget deck that is very reliable.
  3. digitaldave
    digitaldave
    Jan 7, 2003
    261
    St Evenage
    +12
    Morning bump for more input :).
  4. Beobloke
    Beobloke
    Aug 10, 2004
    1,312
    Out in the Sticks!
    +65
    Yes, the dearer Pro-jects are worth the extra, and the carbon fibre arm versions can take better cartridges which will allow for more future upgrades.
    The Rega is, of course, another option worth considering, but personally I'd go for a Pro-ject.
  5. CJROSS
    CJROSS
    Nov 16, 2000
    5,072
    +343
    Main differences are that you can generally pick up Projects a lot cheaper than their respective Rega counterparts, for example you can easily land a Project RPM4 for £200 ex-dem. I quite like Project decks and always give them the push, Many love Regas. But with £200 in my pocket I would be looking for a RPM4.
  6. cwilson
    cwilson
    Feb 5, 2005
    403
    scunthorpe
    +48
    i would look for a second hand rega p2 or 3. the 2 with glass plater is
    probably the best bet.
