Turning Rel strata 2 on its side help
RobTi
Hi when i moved into my current house (upstairs flat) i disconnected my sub and put it away, now looking to set it up again and i am looking for help with keeping the neighbours happy.
Do i keep it as is and put slab or something under it still firing down or could i turn it on its side, or what?
Don't mind removing the feet and refitting if on its side is recommended
Robert
IronGiant
I'd leave it down firing and put it on a slab.
RobTi
Thank you for the reply, now what size of slab would i need as in area beyond the sub, if the sub is 450cm square what would you recommend size wise also would it make any difference going for 2 slabs or would 1 do?
Robert
missinglink
I also live in an upstairs flat and own a REL Strata 2. Stone slabs do not work very well (yes I tried them).
I use a foam/mdf purpose made platform. (I actually have one stacked on another). Mine are made by Auralex - a subdude perched on a gramma which was intended for my guitar amp.
Other similar products exist - see 'Studiospares' or 'HTFR' for isolation/acoustic products as a start, or make your own.
The bass improved in terms of definition and seemed to go lower.
Most important is a considerable decrease in bass transmission through the floor - moving to another room showed that the bass was much less detectable.
My neighbours say I'm quiet! I can't actually believe that but I am considerate.
I would avoid lying it sideways on.
IronGiant
Robert
just one under the cone, a sub interacts with the room it's in mostly. Ideally you'd isolate it from your neighbours completely, but you can't.
Similar threads
Podcast: LG SN7CY Soundbar Review, Hisense 55U7Q, LG Nano90, Best of the Month, B+W Sigourney Weaver
