turning DNIe on?
Discussion in 'Plasma TVs Forum' started by R15TAR, Jan 3, 2007.
  1. R15TAR
    R15TAR
    how do you turn this on? all i can do is turn the demo on but cant seem to turn the function on. thanks
  2. Fatfreedy
    Fatfreedy
    Dec 15, 2006
    137
    +5
    if your referring to the DNle in the samsung model ?
    It is on ! Its just showing you the differance between on and off . You can turn it off but I left mine on ................. till i sent it back :rolleyes:
  3. R15TAR
    R15TAR
    thanks for the reply. all i can find is where to turn the demo on and off but not the acctual dnie..
  4. spruce
    spruce
    Sep 16, 2006
    1,435
    63
    fife
    +102
    Some people have had problems with "flickering" on bright scenes with the Samsung, you have to go into the service menu to switch the dnie off , its not on the normal settings menu.
    there is a whole thread about this somewhere which tells you which buttons to press to get into the service menu..........be careful , its easy to change other settings
    found it..about half way down page
    http://www.avforums.com/forums/showthread.php?t=403718&page=4&highlight=samsung+owners
