Ah okay, yeah I guess could go with using just normal toggle switch and then just dim from the mobile app (not as neat but doable).Very useful
A few notes to add
The problem with mounting in the ceiling and requiring 3 wires only occurs if you have a retractive centre off switch, so you can dim neatly at the switch. If you have a momentary or toggle switch you only require 2 wires. A momentary switch would still allow dimming at the switch just not as neatly as a retractive. A toggle switch wouldn't allow dimming at the switch at all.
The overheating isn't necessarily just about the load applied more about actual heat dissipation at the module you could try adding add a Shelly Bypass
Is there a way to set the max brightness for a Shelly Dimmer? To be honest, the spotlights at 80% are pretty bright and that could help get around the overheat alerts.
