Turning a 17inch widescreen LCD Monitor into a TV
Discussion in 'LCD & LED LCD TVs Forum' started by m_j_wheeler, Aug 29, 2003.
Tags:
  1. m_j_wheeler
    m_j_wheeler
    Can anyone recommend an tv tuner that i can plug in to a 16:9 17 inch lcd screen(resoultion 1280x768). I could get a pc card but that would mean having to have the pc whenever i want to watch tv, which isnt good. I want a tuner that will plug straight into the back of the monitor using the vga input. I have looked on the internet and the cheapest i can find is about £130. If anyone knows anywhere else that sells something simialr i would really appricaite your input
    many thanks
    matt
  2. ensyed
    ensyed
  3. cjdshaw
    cjdshaw
    Feb 5, 2003
    103
    16
