Turn two scart into more?
Discussion in 'LCD & LED LCD TVs' started by kerplunkuk, Apr 26, 2005.
  1. kerplunkuk
    kerplunkuk
    Can anyone suggest a UK available scart extension box that is suitable for a LCD. Probably have Xbox and gamecube plugged into it, so RGB and non RGB compliant would be good.
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    JS Technology MSC? £50 but the best of the best.....
  3. kerplunkuk
    kerplunkuk
    Do you have a link?
    Will it auto switch between items? Does it sense RGB and non RGB?
  4. Rob1698
    Rob1698
    I like the Vivanco AV Control 5.
    Mainly because it outputs the selected input on all other connectors, including RGB.
    So it is not only a 5-way selector, but also a distribution amplifier.
    This is useful when you want to connect two screens, or a recorder device.
  5. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
  6. kerplunkuk
    kerplunkuk
    Many thanks. I assume it does not come with the connecting scart?
