Turn Off
Discussion in 'Plasma TVs Forum' started by cruncher75, Nov 19, 2003.
  1. cruncher75
    cruncher75
    Nov 1, 2003
    1,421
    southampton
    +117
    since ive had my pio 433-mxe 4 days ago. My vcr,cable and dvd have been turning themselfs off when watching them or just brings up the menu screens. They have never done this before only started since they have been hooked up to the plasma anyone else have this happen
  2. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    26,566
    The Borders
    +3,027
    cruncher75
    I take it you mean the Plasma stays on and the rest of the kit goes off or into standby!
    It could be your overloading a mains distribution block and causing it to overheat or if you have an IR repeater system the magic eye is picking up on stray IR from the display and you need to reposition to magic eye.
    I'd switch it all off and double check your wiring and then run the system bit by bit until you can track down the problem.
    Best regards
    Joe
