tupt 600 media box
Discussion in 'Plasma TVs Forum' started by oanyego, Jun 4, 2005.
  1. oanyego
    oanyego
    Apr 21, 2005
    can anyone point me in the direction of reviews of this product or explain why it has received such a bad press?
  2. nak
    nak
    Dec 20, 2004
    146
    Birmingham
    +12
    Hi oanyego,
    The Panasonic Media Box with analogue tuner was supposed to be a one-stop solution to all your hook ups.
    However bad on-board switching meant that your lovely DVD component signal was plagued by jaggies, halos/ghosting and in some boxes - chroma lag.
    If you're an analogue die-hard who craves Fastext, then it does that job perfectly well. But get a seperate component or DVI board for your full DVD enjoyment.
    (It's a shame nobody has made a hybrid Pioneer to Panny connection as the Pioneer media boxes are a work of art)
  3. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    Hmm Pioneer media boxes are actually made by sharp arent that good either, however connecting the TU-PT600 disables all other video cards, so you have to have it and put up with it or Bin and do things properly............
  4. nak
    nak
    Dec 20, 2004
    146
    Birmingham
    +12
    If the Panny tuner is put into off mode and you resort to the original remote and change the input you will be able to use the other slot(s)
  5. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    Not exactly user friendly is it tho (doesn't tuner need to be OFF not in standby too)
  6. Baron Von Doom
    Baron Von Doom
    Mar 15, 2005
    1,548
    worthing
    +137
    tuner needs to be off with switch on front not on standby
  7. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    thought so, not an ideal solution..........especially as PQ is crap...........Dump the tuner
  8. oanyego
    oanyego
    Apr 21, 2005
    Hornydragon, thats my plan to do things properly...
    i just wanted to get a more in depth idea of the problems with the media box. A mate at richer sounds has offered to exchange media box, for the necessary alternatives plus a little cash. What would you recommend.
    I have the panasonic surround sound which is supplied as part of their all in deal with 37" pw7b
    and a pioneer dv 575 dvd, I want to add a decent freeview box to this plus the necessary inputs.
    Any pointers would be much appreciated.
  9. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    Component for DVD and a JS tech RGB to VGA for FV (Topfield PVR seems best of current crop)
