My parents currently have Sky TV but they are getting older now and they are struggling with switching the TV on, and trying to access the Sky channels as they sometimes press random buttons and inadvertently switch the Sky box off, or the TV and then don't know what to do. Sometimes the Sky box is in standby and the TV comes on but the Sky box doesn't. Sometimes they turn off the power at the wall, or on the TV itself etc. Long story short they can't comprehend the basic operation anymore and they get very frustrated. They are located in an area in Ireland where there is no FTA aerial reception for SAORVIEW, so the only way to get a TV signal reception is via Satellite.
They recently purchased a new LG TV (OLED48C16LA), which has a single satellite F connector input. My goal is to get rid of Sky, simplify things so that they just have the TV remote and can get RTE and the UK channels through the TV with no set-top box involved. The TV allows mapping channels to the remote buttons, so e.g. BBC 1 could be mapped to the number 1 button on the remote, and RTE2 could be mapped to number 2 etc.
The TV itself can only get the FTA UK satellite channels at the moment (no SAORVIEW channels are received). Its probably worth noting that the sat tuner is not a Freesat tuner as far as I can tell, but its picking up all the usual Freesat channels, and the picture quality is very good. SaorSat is broadcast on a different satellite from the Astra one used by Sky, so the one dish can't be used for Freesat/FTA UK channels + SaorSat channels.
The only viable solution I can identify is to install a second dish on the house, pointed to the Eutelsat 9e satellite, and run the cable into a 2in 1out DISEQC switch along with the existing Sky dish cable. The receiver in the TV is DISEQC compatible, so my thinking is that the combined signals can be decoded by the tuner to allow mapping of an Irish SaorSat channel, e.g. RTE on to one remote button, and a UK channel e.g. BBC1 to another button.
So can you advise if this makes sense, and if a new dish is installed, will it be possible to map the 2 different sources to buttons on the remote. If it is going to require extra presses on the remote to navigate through different menus to switch between satellite sources then its no good. The end game with this is to have a super simple setup.
Ideally I am looking for a response from someone who has this specific set up and can confirm 100% that this makes sense and does indeed work.
If this cannot work I think the TV will have to go back and I'll have to find another TV that can make the dream possible (maybe a Panasonic with dual Sat tuner inputs).
Thank you in advance.
Paul
- Turn on the TV and its on a TV channel (whatever channel was displayed when the TV was last switched off.
- Change channels by long pressing the number buttons on the remote (that I have mapped to TV channels.
Paul
