tuner or ebox
Discussion in 'General TV Discussions Forum' started by jmack, Jul 12, 2002.
  1. jmack
    jmack
    hi i have a philips 42fd9964 with tuner dvd and ntl plugs in to the tuner then a vga cable to screen
    would i get a much improved picture if i was to go straight from the ntl,dvd, to the screen with rgb to vga cable and miss the box out
    as ihave heard these boxes degrade the source
    thank you
    is there a box i can get with 2 or 3 scart imputs then vga out
    or am i just going to be doing what the tuner does alrerady
    any help much appreciated
  2. ajb
    ajb
    Jul 17, 2001
    454
    Chester Area
    +8
    Buy a Quattro+ scart control centre from www.beyondhifi.net as this has 3 RGB scart sockets and you can choose which to use. Then use Dr Sim's box to convert the RGB into VGA.
    Hope this helps
    Andrew
  3. jmack
    jmack
    cheers for answer but will this make the picture better
  4. ajb
    ajb
    Jul 17, 2001
    454
    Chester Area
    +8
    To be honest I have no idea what the Philips tuner box does and whether it does it well, so I can't help this time round.
    Sorry
    Andrew
