Tuner for my plasma
Discussion in 'Plasma TVs Forum' started by ntranced, Sep 18, 2004.
  1. ntranced
    ntranced
    Aug 12, 2004
    11
    Can anyone advise where I might be able to get a tuner thats universal or will work ok with my Daewoo Plasma?
    I don't particularly want to spend a great deal of money as it's purely for backup when the sky+ isn't working.
    I cant use my VCR as a tuner as my plasma has no scart inputs, and I cant use a freeview box because it only has scart out.
    Hunting around on the net has brought very little, but I'm sure there must be something out there??
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    What inputs does it have? and there will be a way to use VCR or freeview....
  3. spook
    spook
    May 18, 2004
    157
    depending on which inputs your daewoo has, you should be able to get a converter to change the scart output of a freeview box to connect to your plasma.
    if your screen has a vga input you could use the JS scart ot VGA unit.
    Spook
  4. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    Unlikely to work with a daewoo, it won't support the required horizontal sync frequency on VGA. But s-video or RGB scart will work from any freeview boxof course, and that might set you back £50, is that what you had in mind?
  5. Unlight
    Unlight
    Jan 6, 2003
    1,524
    38
    Belfast
    +9
    Quick questions - Do VCRs have a tuner in them then?? So I can use a VCR plugged into the Scart of a PW6 as a temporary measure to watch TV?
  6. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    They certainly do, but with just a composite signal I think you'll be right about temporary.
  7. ntranced
    ntranced
    Aug 12, 2004
    11
    My Daewoo has VGA, RGB component and S Video/Composite inputs. I've bought a couple of SCART - S video but they dont work... I'm not really bothered how they connect - just as long as they do!!
  8. oliver24
    oliver24
    I get the feeling you havent set any of it up yet??
    If not firstly sky
    Throw the cables you bought in the bin :laugh: get a normal svideo to
    svideo cable and plug in at sky+ and other in to plasma.
    VCR
    Get a scart to to av phono lead, connect the yellow end to the composite
    video on the plasma, then you can use vcr as back up tv tuner
    DVD (If you have one)
    Hopefully you have a dvd player with component output's if
    so 3 phono to 3 phono component video lead, as good as you
    can afford, ie Mark Grant cable from here
    Of course this is all video only not audio and before we get into
    that will you be using a Amp (Recomended) or plasma speakers??
    because agian if you have a AV amp that can upconvert to component
    that make's it really easy to switch between sources
  9. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    For this to work they need to beScart>4 pin mini Din and they need to be connected to a device that will output S-video signal via its scart socket (rarer than you think..........)
    My reconmendation would be to but a HUMAX PVR8000T as tuner.
  10. ntranced
    ntranced
    Aug 12, 2004
    11
    Thanks for the advice.
    For Sky, thats exactly what I've done. Same for the DVD player.
    I have a scart to av phono, but when connected I can see a picture, it's just that its mono, and very fuzzy. I've tried changing to a new lead but no success there either...
  11. oliver24
    oliver24
    Sounds like thats a Composite cable which is going to look poor
    compared to the Svideo cable, but what do you mean by mono
    Ie Black & White?
