Tubes for Seleco
Discussion in 'Projectors, Screens & Video Processors' started by cole trickle, Nov 22, 2004.
  1. cole trickle
    cole trickle
    Can somebody pls tell me what the no.s are on the side of the tubes for a Seleco Svp 400ht,
    I've got a chance to go to a factory that is closing down which has some stock of old unit's,
    And also what would be the approxiamate distance i will need to place my projector which is fitted with HD-6 lenses to fill a 115" screen (ceiling front display)
    Thanks Inadvance Dale
  2. Chris Frost
    Chris Frost
    Jul 14, 2000
    2,782
    Cheshire
    +109
    Last time I looked it was something like Sony CRT475 07MS.
    rough rule of thumb is Projection Distance = Screen Width x 1.5
    the Width being the side-to-side measurment and not the corner to corner diagonal in case you were wondering. This works for 4:3 and 16:9 screens.
    One thing to check before you start to install a used projector is the projected image for any signs of phosphor wear. It will show up as a step-up in brightness around the edge of the picture.
    If it isn't too noticable then follow the rule of thumb above. If there is a big change in brightness then you'll need to increase the projection distance to compensate.
    Regards
  3. cole trickle
    cole trickle
    Thanks Chris much appreicated,
    Dale
