Tube Cost
Discussion in 'General TV Discussions Forum' started by clancol, Oct 12, 2003.
  1. clancol
    clancol
    Sep 6, 2003
    1,034
    38
    Middlesbrough
    +7
    Does anyone know how much a tube will cost to buy and fit into my parents 28inch hitachi tv. i think its the blue one
    ta
  2. nathan_silly
    nathan_silly
    Not economical to repair- a new tube & labour cost will probably be higher than a brand new 28" TV.
    Just buy another TV.
    Although it could be another fault, dry solder joint etc, which will be repairable.
  3. Garrett
    Garrett
    Apr 21, 2001
    39,876
    2
    167
    The best thief you’ll never see.
    +6,533
    You may as well put the price of one, to a new TV as if the tube has gone no doubt the other components will be going as well.
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    unless its a hi spec set under 12 months old a new tube is an uneconomic repair! TV's only have one tube and most use 3 guns so i would suggest you take it to a local repairer for an estimate, most will do free estimates!
