Quantcast
TTT 720p
Goose74
Just thought people want to know that TTT 720p (WMV9) has been rereleased on Suprnova (BT)
There are also some samples floating around for Matrix 2 as well as the full FOTR etc
Check out the HDTV Releases thread in the suprnova forum
cheers
Goosie
apul
FOTR and TTT are both there right now, both claiming AC3. they but only have one seed, which means (in my experiance) a painfully slow download.
There is a short clip of TTT where gandalf gets his white horse. this downloaded very quickly for me. :thumbsup:
sadly the clip wasnt the best HD ive seen, looked abit soft.
Singh
i think fotr (in .ts format) is AC3 2.0 and ttt (in wmv9 format) is AC3 5.1 but i only got the samples...
Goose74
Yes FOTR is in ts 2.0
I have not got TTT yet but its downing at full speed.
I do not think that TTT sample is from the Full TTT release - as its cropped 16:9 and the full release is supposed to be OAR
M
Mike65
Have these high definition movies been made for TV broadcast in the US or something?
pj
yup! the two towers i had awile back was cropped but in 5.1
P
pdundas
Almost certainly. If they're cropped (i.e. 16:9) they are probably off HBO as they crop most 2.35:1 material to 16:9.
rigman
What would be a good spec of PC to play these movies? May be a better investment than buying a euro 1080 box.
My current PC is a 1 gig Athlon which has no chance of playing anything
thanks
Darren
pj
thanks
Darren
i have a p4 2.6ghz with radeon9600 graphics card and 1 gig of ram and they stutter! the windows demo ones play fine but all the newsgroup stuff mainly .ts and .trp files lose it a bit!(i.e u wouldnt watch a whole movie like it!)
anyone got any tips or a spec that plays them fine?
Similar threads
