TT1 V2 Euro maps on sd ???
Discussion in 'ICE, Sat Navs & Dash Cams Forum' started by Kaiesha, Apr 24, 2007.
  1. Kaiesha
    Kaiesha
    May 7, 2006
    36
    Wolves
    I have TT euro maps on CD. I had them installed on a 1gb card and used it in my mitec mio and it worked fine.
    Just bought a TT1 v2 and tried the same card in it and it doesn't work, it doesn't recognise the card, it's not locked by the way.
    Does anyone know if the TT1 V2 will only accept official TT cards or is there around what I'm doing?
    Don't really want to spend anymore money if I can help it.
    Should have spent the extra £30 and got the TT europe but I thought the old card would work fine.
    Any help is appreciated. Thank you:thumbsup:
  2. jaymac
    jaymac
    Jan 15, 2003
    1,726
    63
    North Somerset
    +138
    It'll accept any sd card but a bit fussy as ti how you do it. I tried using explorer but TT would'nt recognise had to use TT home used Sandisck card. As a trial I just copied everything on the original card and put it on the other card which is now running
