Tsohiba520E DVD-A 5.1 output
Discussion in 'Blu-ray & DVD Players & Recorders' started by kim@cheung1957., May 8, 2003.
  1. kim@cheung1957.
    kim@cheung1957.
    Just got the Toshiba 520E, DVD-video section is very good. But when i put The DVD-A (The Corrs in Blue), can't get D.D.5.1 signal output from my Yamaha AX630. My audio connection is using a optical cable. Why it only comes out stereo sound?When playing the disc, i checked the audio output from the DVD player, it shows 6-channel signal . Pl. tell. Thanks.
  2. Gary Lightfoot
    Gary Lightfoot
    Apr 6, 2001
    12,305
    Surrey. UK.
    +2,017
    Hi Kim,
    Don't you have to use the analogue outputs from the decoder for DVD-A (the 6 outputs on the back)?
    I don't think you get the correct audio via the spdiff or optical out.
    Gary.
  3. kim@cheung1957.
    kim@cheung1957.
    Thanks Gary! i get the right connection now. Thanks again.
