.ts file transfer Humax 9200T to PC
Discussion in 'Digital TV & Video Players & Recorders' started by jennifer, May 2, 2007.
Tags:
  1. jennifer
    jennifer
    Feb 26, 2007
    125
    +5
    I transferred recorded .ts files to my PC.
    On Channel 5 I get no Audio after processing and notice that the .ts file contains:-
    MPEG AUDIO #1
    MPEG1, Layer 2
    single channel, sampled at 48.0 kHz.
    Bitrate 64 kbps
    Each frame contains 24.0 ms audio (192 bytes)
    First PTS: 11:59:45.907
    MPEG AUDIO #2
    MPEG1, Layer 2
    stereo, sampled at 48.0 kHz.
    Bitrate 192 kbps
    Each frame contains 24.0 ms audio (576 bytes)
    First PTS: 11:59:45.787
    On my tests for BBC2 and ITV1 I get:-
    MPEG AUDIO #1
    MPEG1, Layer 2
    Bitrate 192 kbps
    First PTS: 05:35:12.562
    MPEG AUDIO #2
    MPEG1, Layer 2
    Bitrate 64 kbps
    First PTS: 05:35:12.730
    I notice the difference is that the stereo is in different streams
    How can I get sound from the channel 5 transfers?
    JH
  2. Paul Shirley
    Paul Shirley
    Sep 27, 2004
    1,354
    63
    +174
    Many channels have 2 audio streams, the main one and a second lower rate Audio Description for the blind. More often than not the AD stream is empty.
    Normally the AD stream will have an ID 1 higher than the real audio and playback software will guess right. I assume you ran it through ProjectX or something similar - those tools assume the 1st audio packet seen is the main stream and renumber the streams. About 25% of files will have an AD packet first and switch the audio channels - its not just C5 either, it happens on all channels with AD streams.
    To fix: demultiplex, you'll get 2 .mp2 files, discard the smaller one, remultiplex. In ProjectX you'll have to mess with the PID filter options to fix this in any other mode - I don't recommend it.
  3. jennifer
    jennifer
    Feb 26, 2007
    125
    +5
    I am using PVAStrument to Demux and TMPGenc dvdauthor to edit and write to DVD format. So what do you mean by re-muxing?
    I get 2x .mpa files after demux and the video of course.
    OK I added the audio file manually in TMPGenc and all is well
    JH
  4. Paul Shirley
    Paul Shirley
    Sep 27, 2004
    1,354
    63
    +174
    Demuxing breaks MPEG into the individual audio,video and data streams, in separate files. Multiplexing is the opposite, it combines the individual streams in one file. You can do it manually or most DVD authoring tools will do it for you.
    Also: .mpa & .mp2 are just different names for the same file, different tools choose different names ;)
  5. jennifer
    jennifer
    Feb 26, 2007
    125
    +5
    Thank you so much for the help. I am about to do anothertest on an episode recorded yesterday - Columbo!
    JH
