trying to use my wii settings on ps3 but wont work ???/
Discussion in 'Playstation Forums' started by acemelhaz, Apr 24, 2007.
  1. acemelhaz
    acemelhaz
    Jul 21, 2005
    196
    portsmouth
    +13
    hi i am trying to internet share from my mac to ps3 with no luck ??? it took me ages to work out how to do it with my sons wii and that is working he surfs the net ect . but ive tryed using the same settings on the ps3 but wont work ??? cant understand why can any1 help please
  2. Moogle
    Moogle
    Aug 28, 2005
    13,751
    London
    +1,398
    Sorry I can't help you with your predicament. However I would like to suggest you consider getting a wireless router as it would make things a lot easier and more conveniant.
  3. Jim_Fear
    Jim_Fear
    May 17, 2005
    1,801
    Caterham
    +59
    Hey buddy, what kit are you using to get on the net then?
  4. Moogle
    Moogle
    Aug 28, 2005
    13,751
    London
    +1,398
    Looks like he's using internet connection sharing through the Mac using the Mac as a router.
  5. acemelhaz
    acemelhaz
    Jul 21, 2005
    196
    portsmouth
    +13
    im using ethernet cable from modem into imac then on wii using internet share so doesnt make sense same settings wont work on ps3 ehh
  6. Jim_Fear
    Jim_Fear
    May 17, 2005
    1,801
    Caterham
    +59
    Do you have cable or ADSL?
  7. acemelhaz
    acemelhaz
    Jul 21, 2005
    196
    portsmouth
    +13
    i have cable
  8. M1keF
    M1keF
    Mar 3, 2004
    545
    +70
    are you using a standard patch lead or a cross over patch lead to connect the mac to the PS3?
  9. acemelhaz
    acemelhaz
    Jul 21, 2005
    196
    portsmouth
    +13
    i am using airport
  10. Moogle
    Moogle
    Aug 28, 2005
    13,751
    London
    +1,398
    Is that a Airport Extreme or Express base station ? If so then why are you using ICS through your Mac. Wouldn't it be better to connect the Wii and the PS3 wirelessly direct to the Airport ?
  11. acemelhaz
    acemelhaz
    Jul 21, 2005
    196
    portsmouth
    +13
    im using the built in airport in imac for wii
  12. Tony Hoyle
    Tony Hoyle
    Aug 4, 2005
    3,347
    103
    Stockport
    +231
    AFAIK that doesn't have a DHCP server (or possibly my boss doesn't know how to configure his powerbook :D) so you'll have to do a manual setup.
    Also set it up with no encryption. I've had enough grief myself trying to connect to macs to know it doesn't work (even WEP doesn't seem to be compatible except with other macs).
    He now has a neat little airport device that plugs into a socket and is not much larger than it.. about the size of a small power brick... much simpler to configure & works with everything we've thrown at it. I'd recommend one of those.
  13. Moogle
    Moogle
    Aug 28, 2005
    13,751
    London
    +1,398
    That's probably the Airport Express base station.
