Trying to record from Optical Out
Discussion in 'AV Receivers & Amplifiers' started by Nearlydown, Sep 17, 2007.
  1. Nearlydown
    Nearlydown
    Dec 5, 2006
    2
    I have been trying to record the sound from some HDDVDs onto MiniDisc but all I getting is clicking. I've tried just recording the TV and this works.
    I believe this may be down to Dolby Digital as it only appears to work when I select channels (on Sky) that are not in DD.
    The Minidisc recorder is an old portable unit.
    Any ideas on how to solve this.
    The AV Amp I have is a Yamaha DSP AX640.
  2. rEVILospud
    rEVILospud
    May 1, 2005
    2,295
    Shoreham-by-Sea
    +235
    Tell the HD DVD player to only output in stereo.
  3. mossym
    mossym
    Apr 5, 2006
    13,152
    Ireland
    +2,802
    spdif has a copyright bit that is set when you are outputting sound from a dvd..not sure if it is present in stereo but i think it is(it's definitely set for 5.1 trackes). if it is set you won't be able to record...
  4. Matt_C
    Matt_C
    Aug 14, 2005
    9,867
    Essex
    +1,847
    I belive it is present in both multichannel and stereo, as a restriction on digital recording... So you won't be able to record anything using the optical output if the disc contains the copyright restriction...
