trying to get Netgear WG511 to dhcp to my router?
Discussion in 'General Video Gaming Chat' started by chillo, Dec 24, 2004.
  1. chillo
    chillo
    Sep 15, 2004
    767
    Northern Monkey!
    +34
    Help,
    rebuilt my laptop today with xp sp2 and i cant get my netgear pcmcia card to dhcp the right i.p. address!
    the router is netgear dg834g
    it should pick up 192.168.0.# (# = anything between 2-255?)
    instead i get 169.254.175.110!! what the fudge??
    help? i have tried putting it in as static i.p. address but that won't work for some reason?! :lease:
  2. buzlightyear
    buzlightyear
    Oct 8, 2002
    959
    46
    London
    +119
    The 169 IP address is a generic one that windows gives out when it cannot find a dhcp server. The Netgear card is not seeing your router correctly Is that model a wireless one or hard wired?. If its wireless have you turned on encryption etc on the router make sure you typed excatly the same security settings on the network adaptor as on the router? If hard wired check drivers of the network card maybe try another ethernet cable. Merry Christmas
  3. chillo
    chillo
    Sep 15, 2004
    767
    Northern Monkey!
    +34
    Sorted! thanks for the help! yehaaar!!
    turned off encryption and the re-enabled it and all ok! must have typo'd the wep key!
    doh!
    thanks Buz!
  4. Kazman
    Kazman
    Jan 14, 2004
    5,349
    Luton, Bedfordshire
    +142
    Let me know how it performs mate, the netgear has a good rep. I just bought the Belkin, and it has been great so far. My brother might get a wireless bridge for his xbox soon, so deciding what to recommend.
  5. chillo
    chillo
    Sep 15, 2004
    767
    Northern Monkey!
    +34
    well the wg511 card in my laptop is great, i have a buffalo g54 wireless bridge for hooking up to xbox live which i haven't been able to get working as yet
  6. Kazman
    Kazman
    Jan 14, 2004
    5,349
    Luton, Bedfordshire
    +142
    I gave up with the Buffalo wireless bridge I bought, couldn't get it to work, the Belkin worked almost straight out of the box!! :eek:
