trying to connect xbox 360 to pc, for windows media connect AGGHHHH
bellyfluff9
HELP,
this is driving me crazy, i have the xbox hooked upstairs and it connects to xbox live no problem. however, now i am trying to connect to windows media centre, but with no luck. I have Mcfee security suite installed and to date i have disabled firewall, uninstalled privacy service and windows media connect still wont install.
Please help somebody
Many Thanks
b
danwalton
are they both wireless connections? if so, mine wouldn't work either until one (either the xbox OR the PC) was connected to the router via ethernet cable. Hope that helps :)
smiffy333
Interested to know as well as I can't get the xbox to connect to the media center pc. Both are hard wired and I've been through the various set up steps several times, disabled Norton but the pc can't see the xbox at all.
Br0ken
HELP,
...i am trying to connect to windows media centre, but with no luck. I have Mcfee security suite installed and to date i have disabled firewall, uninstalled privacy service and windows media connect still wont install.
You don't need to install Windows Media Connect if you have a pc running Window Media centre.
bellyfluff9
yes they are both wireless, microsoft say that you have to install windows media connect so how does it work if you dont have to?
Have also spoken to Mcafee and they were about as much use as a chocolate fireguard, i am now thinking its perhaps the firewall in the router, will check out the Belkin website later.
after trying to install windows media connect, the two error messages that came were 1: cannot connect to xbox due to Mcafee firewall and 2: (after disabling firewall and privacy service) cannot find xbox on network.
I think hard wiring one is possibly the way, will have to wait until i get a phone point installed in the study
J
danwalton
care to tell us how? ;)
Podcast: Reported HDMI 2.1 bugs, Audiolab Amp & LG LED Projector reviews + Best of the Month
