May I first say "Novice" is an extremely polite way of explaining my knowledge of speaker building.
So to my Question. I have a Klipsch rf-62ii (centre channel). It contains two drivers one tweeter. I wanted to be able to buy two tweeters and re-purpose the drivers. I would use them as rear surround as I am currently running 5.1 .
The more I read the more complicated building a speaker seems to be . I'm not looking for perfection just some decent surrounds and the accomplishment of building it myself. Can someone suggest a cabinet size and a decent tweeter and crossover, or any other information I should know
rf-62ii specs
Frequency Response 57Hz-24KHz ± 3dB Power Handling 150W RMS / 600W Peak Sensitivity 98dB @ 2.83V / 1m Nominal Impedance 8 ohms compatible High Frequency Drivers 1” (2.54cm) Titanium diaphragm compression driver mated to 90° x 60° square Tractrix® Horn High Frequency Crossover 1500Hz Low Frequency Drivers Dual 6.5” (16.5cm) Cerametallic™ cone woofers.
Any help would be appreciated
rf-62ii specs
