trv33 pc problem
Discussion in 'Camcorders, Action Cams & Video Editing Forum' started by roym, Jan 1, 2004.
  1. roym
    roym
    Sep 13, 2002
    63
    the problem i have is that when i connect my camcorder via firewire the computer recognises it but i can not get it to work in moiviemaker 2 or the imagemixer software that came with it. the imagemixer says no camcorder found and i cannot shut it down until i turn off the camcorder. in moviemaker it just takes forever to do anything then does nothing. the camcorder shows in my computer so i am at a total loss i am a complete newbie please help
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,131
    Rainham Essex
    +2,393
    Often people will have problems with software finding a camcorder if they connect it in the wrong order.
    try it in this order:
    1. Boot PC
    2. Connect camcorder to PC via firewire.
    3. Power on the camcorder.
    4. Start editing programme.
    If all is connected correctly the software should now be able to see the camcorder.
    HTH,
    Mark.
