TRV30 Replacement
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by mikec162, Mar 3, 2002.
  1. mikec162
    mikec162
    Oct 30, 2001
    3
    Recently decided to buy a video camera and having done a fair amount of investigation I decided on the Sony TRV30. Unfortunately, no sooner had I chosen this one I find it had just been discontinued.
    So I have two questions if anybody can help please.
    1. What would you recommend instead of the TRV30, and
    2. Does anybody know what Sony are planning to replace the TRV30 with and when?
    thanks
    Mike C
  2. rolyk
    rolyk
    Whilst Sony are no longer supplying the TRV30 many dealers still have them in stock. I got one two weeks ago from John Lewis who price matched one of the lowest prices in Camcorder User.
    The TRV50 is the replacement and unless you particularly want Bluetooth and several other very minor improvements I would try and find a TRV30. You'll also save yourself a couple of hundred quid as the new model will be more expensive, certainly in the few months after its May launch.
