A
ashmorel
I'm thinking of ordering a Sony DCR TRV 80 from the USA because they are so much cheaper than they are over here but first I would like to know if there is anything I should be aware of other than the warranty? My TV is NTSC compatible and I don't have any old camcorder tapes that I would need as this will be my first camcorder. When you write the image onto DVD, does the image get converted to PAL or is it possible to convert it into PAL? Will UK MiniDV tapes and accesories work OK on the US model?
Any help on these questions and anything else I should be aware of would be much appreciated.
Regards
Lee
Regards
Lee
