truvox dvd
Discussion in 'Blu-ray & DVD Players & Recorders' started by mr.x, Jan 31, 2002.
  1. mr.x
    mr.x
    does n e 1 have a remote hack availibe
  2. Guest
    1) Switch on DVD player
    2) On the remote,press Open/Close to open the tray,then 8,4,2,1
    3)Press Enter.Each time this is pressed the region number changes on screen - All means MULTI-REGION
    4)Press Open/Close to close the tray and the player is set.
