Trust - Multi Connect Bay
Discussion in 'Desktop & Laptop Computers Forum' started by blackstone, Dec 28, 2004.
  1. blackstone
    blackstone
    Oct 10, 2003
    127
    Glasgow
    +4
    I have a USB 2.0 Multi connect bay installed on my machine with the active light on but not reading SD memory card from my camera. I have looked at the trouble shooting section and it might be a cable is not connected inside the PC. The SD card is compatible. Any ideas why it is not reading before I take the PC back to check the ? cable fault. Any advice appreciated :lease:
  2. Rob
    Rob
    Jul 17, 2000
    1,285
    Norwich
    +33
    Sorry if this is obvious, but have you connected the USB (labelled card reader)from multi connector socket into another port?
    Is the SD card inserted with the pin side up?
    Another possibility is that you may need to wiggle the card a bit (I know this sounds daft, but it sometimes works) Worth a try anyway.
    Regards Rob.
