Trust 7.1 Expert 714DX : Please help 2 answer some questions :o)
Discussion in 'Desktop & Laptop Computers Forum' started by nero0410, Sep 12, 2005.
  1. nero0410
    nero0410
    Jan 5, 2004
    12,073
    southwest
    +4,621
    I am considering purchasing one of these sound cards to replace my 5.1 sonicxplosion.
    I would appriciate it if you could help answer some questions for me please.
    THIS is the link to the official site for it, but I can't make head nor tail of it
    My current card only has optical out for the digital sound to my sony str-de697 amp/reciever. And I dont like using optical leads.
    I notice this one has an coaxal out for sp/dif. however it says :
    Equipped with coaxial S/PDIF stereo in and output
    Why does it say it stereo? (this confused me, I even checked it out on the trust site as it does say it is capable of up to 7.1 once and if 7.q is ever released)
    Will it still send a digital 5.1/6.1/7.1 signal out through the coaxal to my 7.1 channel av reciever?
    Does it support all forms of dolby digital, dts etc through sp/dif?
    Thank you very much for your time
    Thanks again
    tris
  2. phunkey_monkeh
    phunkey_monkeh
    Personally, after having a Trust 514DX. I would spend the extra £20 and get a HDA (which is what ive just done)
    The SPDIF can only be enabled when you select headphones/2 speakers in the Trust audio control panel.
    I could never get 5.1 to work in MCE with the Trust card. I spent weeks trying. Others have also had the same problem.
  3. nero0410
    nero0410
    Jan 5, 2004
    12,073
    southwest
    +4,621
    Thanks very much for the reply :)
    unfortunately I can't get another £20 at the moment, and when I saw this 7.1 one for £25 I thought it might be quite the bargain:(
    I have asked the chap who's selling it and he doesn'et know (ebay) and have also emailed trust themselves too.
    What is the HDA?
    Does anyone else have this particular card??
    If so please let me know what you think too
    Thanks again
    tris
  4. phunkey_monkeh
    phunkey_monkeh
    Someone correct me if im wrong.
    But with regards to it referencing 7.1 I believe they mean through the analogue outputs on the card and not the SPDIF.
    oh, and this is the HDA
    http://www.overclockers.co.uk/acatalog/HiTeC.html
    A steal for the price.
  5. nero0410
    nero0410
    Jan 5, 2004
    12,073
    southwest
    +4,621
    That does look a nice card, if only I had the extra :(
    Does anyone else have this particular card?? (Trust 7.1 Expert 714DX)
    Thanks again
    tris
  6. nero0410
    nero0410
    Jan 5, 2004
    12,073
    southwest
    +4,621
    And please reccomend some more cards that may suit my needs :)
    One that can support 5.1/6.1/7.1 dolby digital/dts/dd ex/dts es etc.... through a coaxal output to my av amp/reciever
    Mainly for dvd playback, but some games too
    tris
  7. Jim_Fear
    Jim_Fear
    May 17, 2005
    1,801
    Caterham
    +59
    I have the HDA card and I must say its quite amazing, it can do Dolby Digital live straight through to the optical output, the drivers are as complete as Creative's but they dont crash as much either :)
    It supports up to 7.1 too and has changeable preamp OPAMP circuits so you can adjust the SNR to adjust your needs. I think its a fantastic bit of kit personally.
  8. nero0410
    nero0410
    Jan 5, 2004
    12,073
    southwest
    +4,621
    I do believe that the HDA is a good card, however I do not wish to carry on using optical connection to my av reciever.
    I am changing from my current card so I can have a coaxal connection instead of the optical, and to go up from 5.1 - 7.1 (which is what my av amp is)
    I'm not quite sure what you mean here?
    tris
  9. phunkey_monkeh
    phunkey_monkeh
    HDA has both Optical TOSLINK and Coax SPDIF Outputs.
  10. nero0410
    nero0410
    Jan 5, 2004
    12,073
    southwest
    +4,621
    I would use the coax, or so I thought.
    In a review HERE it suggests to me that for the 7.1 I have to connect it up using analog? I thought I'd be able to use the digital coax for 7.1
    Is it better to connect by analog opposed to coax/optical through my sony strde697 av receiver?
    I thought I'd get better sound using coaxal?
    I am really getting lost now :rolleyes:
    Please help
    tris
  11. Jim_Fear
    Jim_Fear
    May 17, 2005
    1,801
    Caterham
    +59
    On the back of the box it says it supports the following
    DD 5.1, DTS 5.1, DD-EX 6.1/7.1, DTX-ES 6.1/7.1
    This is what it also says in the config options...so i think you're right
  12. nero0410
    nero0410
    Jan 5, 2004
    12,073
    southwest
    +4,621
    That's what I thought :(
    I seem to be back to square one :suicide:
    It would be better getting a card that supports 7.1 through a coaxal connection to my av reciever
    though wouldn't it?
    Or if I used an analog connection would I then use the pc to set up the sound and use the card's decoder instead of my av reciever's?
    What would be best?
    Any idea's?
    I'd like to get one as soon as poss
    I'm also quite stuck as I only have about £25-30 to play with £15 of which is paypal balance the other tenner would come through paypal from my bank
    cheers
    tris
  13. nero0410
    nero0410
    Jan 5, 2004
    12,073
    southwest
    +4,621
    No fear, I'm gonna stick with the one I have.
    Due to the fact that I have been told that if I'm just using the 5.1 sound card to pass through the digital signal and let my 7.1 amp do the decoding it shouldn't make a difference.
    Thanks for all the advice though guy's, it will be of help for future reference :)
    tris
  14. Aardie
    Aardie
    May 2, 2005
    27
    3
    OK I ordered the Trust card a week ago. Only recieved it yesterday and it does do 5.1 DTS and Dolby Digital passthru the Coax just tested it with Dark City on DD and Gladiator on DTS and it passed both through fine allthough you do have to select Cmedia Wave device and not direct sound (which caused the machine to reboot) and this is on XP SP2 OS.
    Hope this helps in youre Decision.
    Regards
    Keith
  15. nero0410
    nero0410
    Jan 5, 2004
    12,073
    southwest
    +4,621
    That might actually make me buy one my friend :)
    As if it does work like that, I believe that it takes the digital sound directly from the disc (be it 5.1/6.1/eventually one day 7.1 maybe, dts or dolby digital) and simply passes it through to the amp for processing.
    I do prefer to use coaxal leads opposed to optical, cos I gotta be so careful with optical cos the break to easily :mad:
    However I did get a messege back from the Trust website simply saying that the signal passed through the coaxal by sp/dif is simply stereo :rolleyes:
    So when you put in a disc does it say on your amp that the sound it what it should be?? On mine it says for example:
    dts-es discreet 3/3.1 (which obviously is 6.1) tested using latest power dvd/win dvd and dvd x player with Lord Of The Rings
    It say's that with the card I have (which is only 5.1) but I use the sp/dif and it simply take the digital sound from the disc to my amp for processing:)
    Please let me know your findings, as I would much prefer a card which I can use a coaxal lead with opposed to optical
    Cheers :smashin:
    tris
  16. nero0410
    nero0410
    Jan 5, 2004
    12,073
    southwest
    +4,621
    up
  17. Aardie
    Aardie
    May 2, 2005
    27
    3
    Yes it does Pass DD and DTS 7.1 you a happy bunny now nero :)
    Apologies for the Delay.
    Regards
    Keith
  18. vigalent
    vigalent
    Mar 7, 2005
    89
    I've got one of these Trust cards (514dx) and can get full AC3 to my amp via the spdif output (not through WMP10 though).
    The problem is, when playing back media with AC3 I get a damn awful rapid clicking noise through my normal pc speakers. What the hell is that about!
  19. cmatt
    cmatt
    Mar 22, 2005
    477
    Edinburgh
    how though?!! ive tired playing with the filters from k-lite codec pack (with out ffdshow) and i STILL cant get it to work :rolleyes:
    :lease: - help?!
  20. guido
    guido
    Jan 13, 2005
    371
    Staines
    +5
    Just got one of the 714DX card last week and hooked up to my Marantz SR5500 via the coaxial digital out... Have been getting pass through no probs with MCE2005 RU2, PowerDVD 6. Have tried DTS, DD 5.1 and all picked up by amp no probs.. first track I tried the amp was saying only 5.0 (no LFE) and was a bit worried, then turned on info in PowerDVD6.. and it said it was 5.0... phew! :thumbsup:
  21. vigalent
    vigalent
    Mar 7, 2005
    89
    cmatt.
    Have you got connected via digital? Heres how I got it working.
    Load the lastest drivers from Trust's website. Start the audio rack application and in tools set your output to either headphones or 2 speaker mode, with spdif enabled.
    Install AC3filter and configure as shown. It works for me in zoomplayer and winDVD, but not in WMP10.
    See this post for more details http://www.avforums.com/forums/showthread.php?t=303965
  22. guido
    guido
    Jan 13, 2005
    371
    Staines
    +5
    The 514DX looks different from 714DX application... but not at home right now so can't post any screen shots... will do so if I get a chance tomorrow.. just for comparison.
