Trunking size for HDMI cables?
Ice_Black
What trunking size do I need for the following cables?
4 HDMI x (Playstation, Sky Box, CCTV, 1 extra spare)
1 Ethernet Cable
Soundbar cable
Plastic Trunking will be in the party wall.
I have decided to buy Samsung TV 65" TV, on the wall where do you suggest I should put Brush plate and plug socket behind tv?
D
Deleted member 24354
It depends, is it a straight trunk or are there any bends in it. Bends will require a much larger trunk.
Koipin
Established Member
I'd use 50 x 50 trunking, which will be fine for that lot. The OneConnect cable off the TV will obviously need to go in small end first.
RAINS
Always place a socket that does not intrude on the TV and take account of the depth with a plug in the socket before mounting the TV bracket. You may need some spacers to push the TV out a little but not too much to put a strain on the fixings on the TV. 50x50 should be fine and feed each one on its own.
Tribit StormBox Blast Bluetooth Speaker: Review Coming Soon
