snow-munki
Established Member
In the process of chasing my walls for cables. The largest trunking I can find is 32mm by 16mm which is fine for hdmi / cat5. But would like to be able to put my xbox one kinect lead through, which is about 15mm X 25mm
So obviously cutting it very fine !
I can find any trunking any deeper, checked all the usual places ( screwfix / b&q etc )
Any suggestions. Found 50mm 50mm trunking but that would be overkill to put in the wall !
Thanks,
Thanks,
