true romance directors cut se
keyser
Does anyone know the differences between True Romance Directors cut... and True Romance directors cut : the special edition??
S
Squirrel God
AFAIK, there are no differences in the movie itself, only in the extras. The SE has some additional extras, including an alternative ending, from what I hear.
DodgeTheViper
As i have the SE.
Squirrel, you are spot on...........;)
Kev
keyser
Is the newer version.. special edition not digitally remastered or in anomorphic an not the other on.. or in dts 5.1.. and not the other one??
DodgeTheViper
Digitally remastered..................Yes
Anormorphic.............................Yes
DTS...........................................Yes
DD............................................Yes
Kev:D
S
Squirrel God
Keyser,
I have the older director's cut as you might have guessed. It is anamorphic and DD5.1. I hope you are not considering buying that one though, as the SE is a good price and should be the only one you purchase now. (If I did not own True Romance at all, I would buy the SE now without hesitation).
http://www2.cd-wow.com/detail_results_2.php?product_code=2942
Only £12.99 delivered ;) You may even be able to pick it up cheaper than that.
keyser
I have the older one and was wondering if i should sell that one and buy the new one.
The cover of mine sais it´s letterboxed.. nothing about anamorphic. It is dolby digital.. but sais nothing about 5.1. And I see nothing about it being digitally remastered. BUTif it is all of that.. anamorphic , 5.1 and digitally remastered... then I see no reason to change. Am only interrested in picture and sound quality.
DodgeTheViper
I didn't have the older one. So i now have the SE.
If i where you...............stick with what you've got;)
Kev
S
Squirrel God
I agree with Mozzer. If all you care about is the movie, then stick with what you got.
BTW, it definitely is anamorphic mate - if it wasn't, I would've binned it. I'm amazed you can't tell just from watching it :eek:
⭐Best TVs, Soundbars, Hi-Fi and Home Cinema of 2023
Back
