True power per channel of amp
Discussion in 'AV Pre-Amp/Processors & Power Amps' started by turnthatdown, Apr 15, 2018.
  1. turnthatdown
    turnthatdown
    Apr 15, 2018
    4
    oxford
    Good evening guys,
    I have an Onkyo tx-nr828 AV reciever,
    could anyone tell me the true "watts per channel" please?
    here is a sample of the spec.
    AMPLIFIER FEATURES
    • 180 W/Ch (6Ω, 1 kHz, 1% THD, 1 Channel Driven, IEC);
    215 W/Ch (6Ω, 1 kHz, 1 Channel Driven, JEITA)
    • WRAT (Wide Range Amplifier Technology)
    • H.C.P.S. (High Current Power Supply) Massive High Power
    Transformer
    • Discrete Output Stage Circuitry
    • Optimum Gain Volume Circuitry
    • PLL (Phase Locked Loop) Jitter-Cleaning Circuit Technology
    it is a 7.2 system and at first glance it looks like all 7 channels are 180w per channel,
    im not so sure!!
    This all came about as im thinking of some Klipsch rp-280f speakers and wanted to make sure my reciever was subitable for the job.
    reagards
    Matt
  2. mick24402400
    mick24402400
    May 12, 2015
    206
    46
    great yarmouth
    +121
    The specs are for 1 channel not 7 channels driven
  3. turnthatdown
    turnthatdown
    Apr 15, 2018
    4
    oxford
    so in real world terms what is the power output to each driven channel?
    assuming at least 5 channels are permently connected.
  4. Rambles
    Rambles
    Jul 14, 2004
    9,556
    137
    UK
    +1,767
  5. turnthatdown
    turnthatdown
    Apr 15, 2018
    4
    oxford
    BOOOOOM, perfect for what i need to know.
    looking at about 100 watts per channel at 5 channels @ 8 ohms.
    im very happy with that.
    thanks for your help,much appreciated.
  6. saster
    saster
    Jan 8, 2015
    224
    46
    Sweden
    +117
    The only TRUE figures, are the ones that shows 20 - 20kHz, all channels driven at 8 ohm and at a MAXIMUM of 0.1% distortion. Not many receivers lists those numbers these days :)
    In modern receivers you are lucky if you get 7x50w (even if listed as 180w x 7).
    One thing you can do, is to look at the specs and find what is listed as max power consumption.. Then multiply that by 0.7 (as amps are only <70% efficient .. a bit more if class D).
    Then divide this by number of channels. Then you have more realistic numbers :)
    Sure, you can increase this with a large capacitor bank, but receivers usually don't have those.
  7. saster
    saster
    Jan 8, 2015
    224
    46
    Sweden
    +117
    The Klipsch rp-280f have a sensitivity of 98 dB.
    This means that 1 W out of the amp will produce 98 dB out of your speaker.
    Then add 3 dB from room gain.
    Then subtract 6 dB per meter listening distance from the speaker.
    So 1 W will give you 83 dB at listening position.. you'll be fine :)
  8. turnthatdown
    turnthatdown
    Apr 15, 2018
    4
    oxford
    Great comments guys [emoji2]
    Thank you
  9. Rambles
    Rambles
    Jul 14, 2004
    9,556
    137
    UK
    +1,767
    The Klipsch are unusually very sensitive speakers, so do not require a lot of power. The 98db sensitivity means it will take 1 watt to produce 98db at 1 metre.
    Movie soundtracks are generally mixed at 85db reference level (0 on most AVRs) with 20db of headroom at peaks.
    The further away you are, and the more you turn the volume up, the more power is needed. For those speakers, at 4 metres listening distance it would take 80 watts to achieve the 85db + 20db headroom.
    But, that doesn't take into account room reflections and the fact that you may be using an active subwoofer and applying a crossover to the speakers to direct the bass to the subwoofer which would reduce the power requirements from the AVR.
